I am using a 12v diesel AC amplifier from a HJ or BJ60 I sourced in Canada.
Recently, I was having an intermittent AC issue and found the AC amplifier connection was loose...easy fix.
But while I was there I removed the AC amp board and cleaned all the connections. That is when I saw the Red Knob! I remember seeing this when I did my swap, but promptly forgot about it.
What does this knob do? Mine is adjusted about 75-85% towards the clockwise stop.
Any advice? Does it work the same a gas model for compressor clutch engagement rpm adjustment?
Doug
Doug
