Tried that. I was just hoping that someone had found the magic cure.I heard something in a past thread about heating a certain part in the trans to bend it a little so it would not pop out?
R
My advise: Find the best deal you can on a new coarse spline H55F out of the US and be done with it
Save yourself the aggravation of trying to replace everything to do with 5th gear in the transmission.
Been through this with the folks old HJ60 ten years ago. After the tranny had been into 3 times by a Cruiser shop... and every part related to 5th was new from Toyota the pop was gone and so was $3500.. Started to pop again in less than 100k km.
Wow that sucks. Is it due to end play on the shaft? ie. bearing wear?
It must be common, I have an 89, same tranny, even the same paint job, same problem. Does it do it often enough to need fixin? When I was in 5th everyday it only happened a couple times a month. I haven't been past 4th in a year so don't know if it's getting worst.(kinda miss 5th)
