I have searched the numerous threads and have made many of the inspections/changes mentioned.
1 new oem plugs,wires, cap, etc
2 Air hose seems okay, has trd sc and no leaks detected
3 CEL code for O2 sensor (replaced) & #6 cyl misfire (replaced #6 injector and intake gaskets)
4 Replaced egr valve
5 inspection of wires across the egr (slight wear on clothy shroud no damage to actual wires detected) secured and no change when wires are moved by hand.
6 Compression and leak down tests are both very good
No change to idle problem.
The vehicle: 1997 TRD SC OME 2 1/2 (Slee 4" on the way) ARB, Warn, 305's etc. 79k
The symptom: A slight 30-50 drop in rpm every few seconds after the truck has been dropped to idle. No other performance issues or irregular occurences.
The only thing that seems to improve the "bump" when idling is to crimp the return fuel line just past the regulator on the fuel rail. It seems to be fuel related. My next step is to change the fuel regulator and test the idle speed sensor.
Are people experiencing any fuel pressure problems with the Supercharger? If so how have they been corrected?
To add all of the work has been done or confirmed by a very reputable Toyota dealer.
Thanks for any guidance.
Although it is my first post, I have read/enjoyed numerous, great stuff.
