The topic of brake pedal feel, proper bleeding procedure and quality of brakes have been discussed many times. But I would like to add this observation as it rarely been done under controlled environment.
The gist of this post to let you know that, in my experience and observation, activated the ABS after working on the brakes is essential.
I would further say that once in a while activating the ABS is a good and essential preventive maintenance since it circulate brake fluid through a circuit that is not often used. This is an assumption and observation. I don't have a hard fact about how it works. But it makes sense logically. So I like it.
Recently Landtank worked on my brakes. He replaced most of the hard lines and the master cylinder. Completely flushed all the brake fluid and properly bled the brake system. For point of reference my rotors and pads are in excellent shape. I rebuilt the calipers about two years a go. The rear rotors are not in new shape, but the front are new this summer.
So, when Landtank finished his work the brakes were good, with minor improvement. It was mostly preventive maintenance and my brakes were fine before he worked on the car (at idle the brake pedal sank a bit to the floor but not all way and that behavior was fixed)
After about two weeks it finally snowed in Albany. We had almost no snow this year but we now had a nice slippery 1" coating on the road. It was an excellent opportunity to activate the ABS. I can't activate the ABS on dry pavement.
I made few 30mph to a stop runs. The next day I made few more. Conditions were such that I was able to activate the ABS on a long slide and I did it on multiple runs.
The brakes have dramatically improved. The truck now stop as good as it should. The difference is not only that it stop so well, there is a good brake feel. Meaning the brake pedal is applying the brakes in a very linear fashion. The brakes are responding correctly from light pressure (slowing down) all the way to a hard stop.
So my recommendations are to somehow activate the ABS once in a while.
Hope this helps
Rami
Hope this helps
Rami
