The radio, clock, and dome lights in my 91 just started not working intermittently. All fuses are good! Can't seem to find the problem yet! Has anyone had the same or similar problem? Or any ideas?
Along the same lines as TrickyT, this circuit gets ground applied at several points for the individual devices, so I would be looking for something common to the items that are flaking out. It seems like it would be the positive side from the fuse or a connection / wire between the fuse and where they separate out to the individual devices. Typical to most intermittent electrical problems, a loose wire, corrosion at a junction, or a wire that has broken but occasionally connects should be the types of breaks to look for.
Good luck.
Fuse blowing indicates a direct short, after the fuse but more than likely before the load. Pull the fuse. Disconnect the power wire from your loads (clock, radio, anything else powered by that fuse) and keep them isolated. Then, using a multimeter, check for shorts to ground. You may be able to isolate where the short is and then either replace the wire or wrap it to eliminate the short. It too could be internal to one of the components, like the radio. By disconnecting it from the power feed and then checking the feed wire and load you can determine whether the wire is shorting or the device. Good luck in the search.
Ok, so first off... that sucks.
It doesn't make sense that it blew the fuse, with the battery disconnected. No power = no fuse blowing. Did you disconnect the negative terminal or the positive terminal? Other thoughts - do you have a 2nd power source in the vehicle? I know that sounds crazy, but I have to ask, since you disconnected the battery and blew a fuse. Second question, did you find all of your loads on that fuse, including any that may have been added by a previous owner?
I hope you don't get upset if it seems like my questioning is going in circles, but my head is spinning from your last post.
