I pulled the valve cover off today to do a routine valve check and adjust. When I got the cover off, I was shocked to see what I'm assuming is antifreeze hanging in the cover (see pictures).
The engine has been running fine with plenty of power for a 3FE. I have been having to add antifreeze for the last 3 months (a gallon or gallon and a half total). I found a couple of those carter pin clamps had rusted in two and failed under the floor board that go to the rear heater. After fixing that, I found another heater hose that was leaking where someone had cut it and put one of those Prestone tee fittings in. I just got the new hose yesterday and replaced it. I assumed I would be done with coolant leaks. I replaced the PCV valve a couple years ago. I would not recommend doing this, but I took my finger and tasted the film and it has an extremely sweet taste, similar to antifreeze.
Any help/advice/suggestions would be greatly appreciated! Thanks!
