semlin
curmudgeon
So this is a bit of a report but might be useful to someone I guess what with everyone's window motors slowly giving up the ghost over time. Just replaced the glass run (rubber seal/guide all around the window, the outer belt (rubber horizontal wiper seal along base of window) and regulator on the driver's window. A bit spendy but I did not replace the motor and now the window works like new even though it was below zero last night. I am also now no longer leaking profuse amounts of water into my door through my worn wiper seal. Plus when I wind my window down to clear my fogged up side view mirror in the morning the new wiper rubs the condensation off the outside of the window for me. It's the little things I guess
Still don't know what was wrong with the system but one of the rollers on the regulator kept popping off and no amount of cleaning the glass run and adding silcone lube or grease on the regulator parts or careful adjustment of the regulator would cure it. The bonus is that with these changes the window now works a lot faster than it did even after all the old stuff was spotlessly clean and lubed. Therefore, you might consider a new glass run and or belt to cure a slow window.
This is not a difficult job but will take about 1.5 hrs. Only hassles are removing the side view mirror to get at the belt and getting the ajdustment right on the regulator so the back of the window runs parallel to the glass slide as it comes down. The only items you need are a phillips and flat head, a 10mm socket and some waterproof sealing tape to close up the door seal. 1
