This thread is a result of Driley's front axle rebuild thread, and will hopefully clear up some of the questions associated with separating the birfields from the inner axle shafts, reassembling the birfields, and reinstalling the axle shafts. Some people may do this simply to clean out all the old grease during a rebuild, others may swap the birfields to the opposite side to coax some more life out of them, and some unlucky folks may do this after their tire passes them on the shoulder of the road
Part A: Separating the birfield and inner axle.
1. Buy a 4' piece of 1.5" inner diameter ABS pipe (the black plastic stuff). Cut it so it is 4"-6" longer than the long side inner axle shaft
2. Place the inner axle shaft into the pipe so the birfield sits on the top end of the pipe.
3. Place a heavy folded up shop blanket on the floor (or stuff the bottom end of the pipe with a couple of shop rags). This will prevent damage to the splines on the differential end of the inner axle when you slam the end of the pipe against the floor/blanket.
4. Hold the pipe in one hand and the stub shaft of the birfield in the other and slam the end of the pipe against the floor/blanket.
5. Repeat until the inner axle separates from the birfield and drops to the bottom of the pipe. Presto!
6. Congratulate yourself for not putting too many dents in the floor
7. Remove the old snap ring from the axle shaft, disassemble the birfield, and clean all the old grease off. Keep all the parts together and label what side they came from.
8. Repeat steps 2 through 7 with the short side assembly.
Part B: Rebuilding the birfield.
These photos courtesy of Driley (it's still too cold to wear shorts in my neck of the woods!)
1. Clamp the empty birfield (tulip) open-end-up in a soft jawed vise.
2. Take a look at the cage and notice that it has a flat edge and a tapered edge. The flat edge goes to the outside of the truck (facing down into the birfield in the vise).
3. Next look at the star piece. One edge of the splined hole (where the axle engages) has a groove where the C-clip will sit when the inner axle shaft is installed. This faces the outside of the truck (down into the birfield in the vise). The edge on the other side of the star has splines that taper down slightly as they near the edge. This is to help guide the axle splines during reassembly.
4. Assemble the cage and star, keeping a close eye on the orientation of both parts, and install into them into the birfield.
Tapered edge (cage) and guide splines (star). This side faces towards the differential (up in the birfield in the vise).
Flat edge (cage) and C-clip groove (star). This side faces the outside of the truck (down into the birfield in the vise).
Installing the cage and star into the birfield.
5. The 6 balls can be installed one at a time by aligning the grooves in the star with the slots in the cage and the grooves in the birfield, and then tipping the star and cage assembly up. The ball should drop in to the exposed space with little to no force (depending on the mileage on the birfs). If you have to push it in with more than one finger, something might be amiss. Check everything again. Drop the remaining 5 balls in, and presto, you have one assembled birf!
6. Drink up!
7. Now, take it all apart, coat everything with moly grease (leave a bunch of grease inside the birfield) and put it all back together again. Practice makes perfect, right?
Part C: Installing the axle shaft.
These photos courtesy of woody (was it that tire?
1. Decide which axle shaft is going in which birfield. If the birfields are clicking during turns, swapping them to to opposite side can extend their useable life somewhat.
2. Install the C-clip in the groove in the axle shaft. It will be loose.
3. Use a ziptie or hose clamp on top of the C-clip to compress the clip around the axle shaft.
4. Align the greased axle splines with the greased splines in the star and press the axle into the star. As the ziptie/hose clamp reaches the star, it will keep the C-clip compressed until it slides into the star.
5. Push the axle in the rest of the way, remove the ziptie/hose clamp and check that the axle will not come out of the birf.
6. Congratulations, you now have one assembled inner axle assembly!
7. Repeat steps 2-6 for the other birfield and inner axle shaft.
6. Drink up!
