...By the way is Wilson 2000 a stainless steel whip antenna?
It is a stainless steel antenna.
Uses Silver Plated 10 gauge, Solid Copper Wire- outperforms copper, nickel, & chrome plating
Easily Handles 3,500 Watts
Large coil housing for increased power handling
Exclusive low loss coil design (Patent #4,882,591)
Made From High Impact Engineering Thermoplastics
Frequency Range: 26 MHz to 30 MHz
Weather Channel Ready
Can be used as a single antenna or co-phased for dual antennas
3/8" X 24" Standard Threaded Shaft
1 Year Warranty
T-2000 Features
5" or 10" Stainless Steel Shaft
49" 17-7 spring stainless steel whip
The Wilson Short Load antenna is 39 inches long and replaces the 62" whip that is standard for the Wilson 1000 and the Wilson 5000. (can be used with the 2000)
