PEASE HELP ME BEFORE I GO NUTS!
1997 Toyota Land Cruiser (fully loaded)
4 wheel disc brakes
ABS
114,000 miles
It has a low brake pedal and feels very spongy. Here is the best way I can describe how it stops. When depressing the brake pedal the truck starts slowing and the further you press it the more it stops, but the pedal travel goes way down low. During a panic stop it is less than an inch from bottoming out, but stops smoothly and fairly quickly. I pulled all four wheels off and checked brake wear. The front pads are around 60+% life left, and the rear pads are around 40-50% life. No gringing, squeeling, or any funny nioses. Honestly it stops very quickly if you hammer on the brake pedal, but it will not activate ABS or lock up the tires like many on here say it should. It just stops quickly. All four calipers appear to be working since all the rotors get hot after braking and they are all wearing evenly. I read through the forum here and many said they changed the master cylinder and the spongy pedal feel went away. I did just that and nothing changed! Yes, I CHANGED THE MASTER CYLINDER! All the hard lines are rust free with NO LEAKS. The flexable rubber lines up front and the one in the rear are all in fantastic shape. What the hell is wrong here. My brake pedal has about 1/4-1/2 free play and feels very nice. I did the master cylinder check and it passes (new and old). PLEASE HELP ME!
Recap:
97' LC with ABS
Brand New Master Cylinder (properly bench blead and installed)
No Leaks in braking system at all
Blead air out of calipers
Rubber lines seem perfect
Even pad wear and all four corners are working
Correct freeplay in brake pedal
Fresh Fluid
I'm guessing air is in the ABS unit and I cannot get it out. Is there a procedure to bleeding air from the ABS unit? Any help is greatly appreciated. If you guys need any more info I'll supply it. I'll even take a video is need be.
Thanks,
Brian
4 wheel disc brakes
ABS
114,000 miles
Recap:
97' LC with ABS
Fresh Fluid
Thanks,
Brian
