scottm
SILVER Star
Hi guys, haven't been here in a while. My remaining 80 has been reliable and needed little but oil and gas. But I recently made the mistake of pulling the running boards and trailer hitch to sandblast and bedliner them, and apparently upset the delicate feng shui of my truck. Details:
-'97 base-model FZJ80, 159k, no lockers or mods, original most everything.
-Fairly new Michelin SUV tires all at good pressure.
-No recent mods, heavy maintenance, or hard use.
-Birf job done a few years ago by me, birfs looked worn, swapped them left-right. They're mostly quiet, sometimes I can hear them slightly.
-Vibration under accelleration from 30 to 50 or so, getting heavier and beginning at lower speeds.
-Found one front wheel bearing loose, adjusted it.
-Lubed the driveshafts, they haven't been done in many years.
-Fluids are all full, front diff fluid is green as usual.
-No noticeable slop in the input or output bearings, but I haven't dropped the driveshafts yet. I'll mark them and drop them when I get this info.
-Long trip coming up the 2nd, we need the cruiser, even if 2wd.
Question: What fuse do I pull to keep the center diff locked when I switch from lo to hi range? I have a CDL switch salvaged from the wreckage of the 40th, but don't really want to tear up the new wood trim to put it in. I've done this before.
There's lots of info on this subject when I search, and I'm following the many great suggestions, but I haven't seen what fuse to pull, and it isn't obvious when I look at my fuse panels. I called IdahoBro, but he's on the road in Texas and his cell isn't getting good reception. There's been much talk of replacing the 80 in my household, this isn't helping. Advice appreciated, thanks.
