wich free wheel hub fit my truck ?
Kuwait
Hi
please any one help me about free wheel hubs , am looking for warn hubs and i wanna order it from amazon or any shopping site but i do not know wich model will fit my car
any one know the model no. and if i need spindle nut conversion ?
help help :crybaby:
this is my car model 2009
Does your 79 have the electrically actuated 4WD and a Hi/Lo shift lever in the cab? If it's an electrically actuated system, then you shouldn't need selctable hubs unless you have the crappy electric hubs. Are the hubs on your truck fixed drive plates or the electric hubs? You can probably get a set of the Aisin manual hubs for it from the 79s from other markets that have the manual selectable hubs.
Which model 79 (base, gx, gxl, gas, diesel) do you have and what market is it from?
Does your 79 have the electrically actuated 4WD and a Hi/Lo in the cab? If it's an electrically actuated system, then you shouldn't need selctable hubs unless you have the crappy electric hubs. Are the hubs on your truck fixed drive plates or the electric hubs? You can probably get a set of the Aisin manual hubs for it from the 79s from other markets that have the manual selectable hubs.
i dont think it is have any thing electrically :D cuz every thing in the car manual and the 4WD Hi/Lo is manual shift not electrical .
my car is landcruiser 79 (truck as shown in first post ) model 2009 gas engine and i bought it from qatar ( [GCC market] gulf cooperation council )
i found alot from warn hubs in amazon.com but i dont know wich one will fit my car
please check the link
Amazon.com: warn hub
thanks all :cheers:
Is it a full time 4wd truck?
I'd go with the Toyota Aisin hubs, best bang for your buck. I'll see if I can dig up a part number for you.
Looks like that hub for a Ford axle, prolly won't work. Warn has a couple of part numbers for the Toyota 30 spline axles, one for the 9.5" toyota axles, and one for the 8" axles. I don't know if it will work with the newer 78/79 series axles. Might be too long or short for the spindle and axle shaft length. Check out WARN Winches, ATV Winches, and Winch Accessories | Go Warn Winches
Here's the Toyota P/N for the OEM manual hubs 43509‑60051 for the 2007+ HZJ-78/79. This is the best option if you go manual hubs
And you can order the center caps to suit the rims with hub access holes in them from Toyota Australia
thanks all :cheers:
So what hubs have you got now then? Or is it fitted with drive plates? Are you sure you dont already have the standard manual hubs under there?
if this came with driveplates, you will need to swap your birfields to make the toyota hubs fits. The birfields that come with driveplates to not allow or fit freewheel hubs. Yes, totally crazy and dumb. teh spline count is different than the birfields that come with freewheel hubs.
Look on ebay in australia (try: ROODOGS 4WD SPARES items - Get great deals on TOYOTA ALL MODELS, OTHER 4WD PARTS items on eBay Stores!).
Or, are there dismantler or "wrecking yards" in your town/country?
I have the same truck. It's a royal pain in the a** to put manual hubs on it. More so than any other cruiser.
yes it came with driveplate ,as you said gifu, am not sure now if AISIN hubs will fit my car or no :s confused
i will check the wrecking yards or i will buy an automatic one from toyota dealer
thanks all brothers
i found this table in AVM website for locking hub , i think its have all info for all cars , after check the chart i think AVM hubs model 455 will fit my car
any one try AVM hub ?
Products AVM
Products AVM
Stay away from those weak pieces of snot
