Hey guys, first off I’d like to say thanks to everyone who contributes to this site. There is a TON of knowledge on here to sift through! Thank you!
I recently bought an 87 FJ60, 220k on it. It’d been a city cruiser all its life. I didn’t run very good at all when I got it. It had the stock tires on it, and wouldn’t go 60mph down the road.
I’ve since done the following:
NEW
4 core radiator
Hoses
Belts
Dizzy cap/rotor
PCV valve
Wires
Plugs
6 into 1 header
Desmog (everything is gone)
Weber (solex?) 34/34
265/75-16’s Nitto Grapplers on Wheelers black steels
Got everything done, the paperboard $hit manifold gasket, that came with the header, lasted all of a week, but I was tired of waiting on one to come in from Toyota.
FYI, Toyota has discontinued the gasket with the exhaust ports split. I found a nice gasket at NAPA for $24 (I think I just threw the part # away this morning! I’ll find it).
Got the gasket from NAPA installed it. It ran good except it idled at 1200 rpms, (wouldn’t drop) and if I tromped it, it’d stutter bad around 2500 and then run fine everywhere. It’d even pull 85mph with 32” tires and 2:73 gears.
I decided to try to adjust the idle mixture screw and get it to idle below 1k and hopefully get rid of the stumble.
The choke was holding the idle high. I adjusted the cam and fixed that.
I tried fine tuning the idle mixture, and now it’s all jacked up. Can’t get it even close. I thought it was a fuel filter, because I could see the fuel level in the old one, and could watch it go down. So I put a new filter on, and checked the screen in the carb inlet. Everything good there.
Then I thought the fuel pump was bad, so I put on an electric one (1-4psi) with a regulator and gauge. Was holding steady around 2.4 psi.
I’ve turned the idle mixture screw to every possible spot (increments of ½ turn) and seem to get nowhere.
I have to feather the throttle to take off, then it bucks and sputters, if I tromp it it’ll eventually smooth out some but not the way it was. Can’t even think about going up a hill.
If I hold the throttle a 1/3 open or so, I can watch the fuel pressure go down to 1psi or less. I can still see the fuel pouring into the filter, it doesn’t stay full; that doesn't seem right.
Is there a screen in the tank? I blew air through the fuel supply from the tank, and through the fuel return, both bubbled and sounded open. No change in the issues.
PLEASE HELP! I really can’t see it being anything but the carb, because it didn’t happen until I adjusted it. But it could be a coincidence.
Don’t chime in about how bad weber’s are, it’s a waste of time. I've read every thread about carbs and plenty of people’s run fine with a weber.
Some love them, some hate them. Right now I hate it, but the damn thing ran, and there is no logical reason why it shouldn’t run again!
NEW
4 core radiator
Hoses
Belts
Dizzy cap/rotor
PCV valve
Wires
Plugs
6 into 1 header
