H55F input shaft
Idaho
Is the input shaft on an H55F different for diesel vs. gasser?
Length?
Splines?
Thanks,
Phil
The B shaft is longer than the F/H shaft, plus the spline counts differ. Also the neck of the front bearing retainer is longer on the B type H55F's. One more tidbit, the HZ input shaft is very similar to the F/H shafts but a little longer. I just went through an input shaft replacement on a H55F (from the B shaft to the F/H shaft), and changing out the input shaft is a royal pain. A shaft change essentially equals a tranny rebuild.
:D Great!
Thanks for the info guys. I was aware of the differences for the 4sp but not sure about the 5sp.
Phil
These are the front shafts for the H55 that suit the 2h and 1Hz. fine spline for the 1HZ, coarse for the 2H.:beer: :beer:
Sweet...
Thanks for pic.
Phil
