Never Done This! Be gentle.
OK, have done searches on how to perform just the front axle inner seal. I haven't been able to find much. Some on the front axle knuckle rebuild but not much. Pointers to Kurt at Cruiser Outfitters. Have not found any "step-by-step" process nor examples using pictures on the forum or FAQ (Woody pictures missing). I have the 1972-1974 Toyota Repair Manual Pub No. 98077-1 (pages 5-1 through 5-28) and Haynes Manual covering 1968 through 1982 FJ-40s. and 55s. I have a March of 1975 FJ-55. The repair manual is not giving me much guidance to accomplish my "focused" task of just repairing the seals that are leaking.
Problem:
Leakage of gear oil down wheel and tire on front passenger side. See Pic.
Checked with Kurt at Cruiser Outfitters and he suggested I tear it apart to make sure I know what is needed before ordering the "Front Axle Knuckle Rebuild Kit." I could just need the inner axle seals. Checked with my local mechanic and based on my description, they suggested just doing the inner seals. I do not have play in the front wheels - suggesting bearing wear is satisfactory? Kurt was saying that he was developing a procedure to do this. However, I need one now.
If someone knows where this process might be described would appreciate sending me a link. Not sure, what all needs to be torn down to get to the inner seals. How much I need/want to disassemble.
Assume drum brakes need disconnecting but not sure I I want to disconnect the steering knuckle if I do not have to. I have not opened it up so do not know. My drum and locking hub is different than the 1972 to 1974 Toyota Repair Manual shows.
Just need some guidance before I wrench this with my son (more of a learning experience for him). Any hints on how to capture the oil that will spill from the axle. To limit leaking, I would park this side on 2x6's to elevate so would not leak. Brakes shoes have not been "crapped" up from oil leakage, yet.
Found this response from "Poser"
Inner axle seal is leaking, and letting gear oil out into the knuckle to mix with the Moly grease that should be in there, and leaking past the rubber ring and felt seal on the back side of the knuckle.
Originally Posted by a6016
Is the repair difficult?
Difficult, no. Messy and time consuming, yes. Get a FSM and get after it. The procedure is called out in there, and there are many threads out here on front axle seal/knuckle seals/bearing replacement.
If you are seeing gear oil on the rear axle drum/backing plate then you have a rear axle seal leaking there also....It could be brake fluid leaking from a wheel cylinder also however...
Good luck!
-Steve
75Pig Pics
Problem:
Good luck!
-Steve
75Pig Pics
