I picked up a used Tri-Mil header from a fellow mudder. I was test fitting it today before I clean it up and I can't see how it's going to make a good seal in its current form, and I'm wondering what other peoples' experiences are.
It seems that the regular bolt and washer don't make contact with the header flange, the slip right by it.
I've searched and heard some mention of washers or shims. Is that what peolpe are doing? Do they come with the header? Are they oval in shape so that they don't exend onto the intake and only the header?
I'm tempted to try and weld some material into the bolt area so the bolt would actually have something to clamp to. I don't understand why they are so sloppy fitting.
In their current state there is little clamping pressure and I can rock the header back and forth with just the center bolts tightened with the intake installed.
