what are good tires to put on these rims, damm they got tubes in them.
All my grand-paw's farm equipment with split rims have to run tubes. Also those wheels are referred to as "Widow Makers" so beware of the ring![]()
seems like there more trouble than the seem
They make great anchors for any boat ,and if you like you can add them to any dumb bell set to increase weight
if your not familiar with split rims have a pro do them .friend of mine got his whole face ripped off by 1 and died . get something safer, when your on the road very few people will want to touch those i agree with all the others on here .old jeep wagoneer had 6 bolt pattern and 16" non split rims not to mention other sources but its your truck good luck
VIVA SPLIT RIMS! People get them confused with widomakers which are entirely a different wheel.
That being said you need to respect them when you are airing up. You can wrap a heavy chain around the wheel and tire when airing up for a safety precaution.
When I change a split rim. I do the following when putting it back together.
a. make sure the split in the ring and the hole on the wheel are opposite eachother.
b. clean the groove in the wheel with a screw driver and feel for any defects. I also clean the ring too.
c. wrap a chain around the tire and wheel to absorb any energy if the ring was to fail.
d. stick about 5 pounds of pressure and stop. Then make sure the ring and tire are seating correctly. Continue airing up.
Here is our 45 with splittys..
Hey Bull,
Who do you get to balance your split rims? I have asked several tire shops if they will balance the wheels/tires if I mount them prior to bringing them into the shop. The tire shops that I have talked to won't even do that. I understand that most tire shops won't mess with them because of insurance purposes. Have you found this to be the case?
Hey Bull,
You may have to go to a rural/farm town. You could also try a truck stop, they deal in split rims daily. I have never had an issue with when we had them balanced. I have found inner city tire places pretty inept.
I always wondered that.tubeless tire won't seal off on split rims....
