Thank You! 3 ton jack stands as well?
I use some 12 ton ones for the frame. Overkill? Maybe.
but when you're underneath a three ton rig cranking on stubborn bolts, the last thing I want to contemplate its that thing wobbling off it's stands, or worse. Pick up some decent wheel chocks while you're at it. Cheap at Harbor Freight.Thank You! 3 ton jack stands as well?
Keep in mind jack stands are rated in pairs, not single. And always have a backup method like sliding the tire back under to create survivable space if the poo hits the fan.
