I want to clean my A/C system because it just smell musty and I don't have cabin air filters that I can change on my LC. Where is the evaporator drain hose? I think it is underneath near the fire wall but have not been able to locate it.
super90 said:One other idea: pull the fan motor and you should have almost direct access to the evaporator. At least the 80-series worked like this and you could clean the coil easily, and clean out the fan, etc. After that, the air from the vents was much, much more "fresh"
