Does anyone know the weight difference between aftermarket 16"x8" steel wheels and the stock 16"x8" alloys?
cruiserdan said:OEM steel wheels are not offered in North America for the 100. The 16x8 OEM steels for the 80 weigh 43 lbs each.
spressomon said:I want to be able to run a 4-wheel set of good traction chains if necessary (there is minimal clearance with stock alloys/offset, 285R75/16" and the upper control/A arm now. I thought by going with steel for my off-road set I could use 1/2" spacers, with the thinner steel wheels, and not have to go with bolt on wheel spacers, etc. and therefore alter the width stance/offset/backspacing minimally.
Just thinking it through right now...I appreciate everyone's input. Although it would still be nice to know what the factory cast(?) wheels weigh.
100 TD said:They weigh 18.5 kg (40.8 lbs for non metric folk) for factory 16 x 8 steel rims EDIT......including rubber style valve stem, excluding centre cap, they look something like this, picture borrowed from web
