Icom ID-880 D-Star 2m & 440 Amateur Radio Install
San Diego
I finally got around to installing my D-Star radio into the LC 100. I ran a power cable directly from the battery (fused at the battery end) .
I mounted the head unit above the sun roof controls and the RF deck in the center console. The antenna was mounted on the back lift gate. I currently run a short 1/4 wave antenna for around town. It allows me to drop into parking structures and my own garage without any issues. I do have a full wave diamond antenna that I will screw on when I go out on the trails.
Install Details:
1. I punched a hole in the driver side firewall grommet using a sharp screw driver. I then removed the driver side door base trim and ran the wire down the door line and crossed over to the center console under the seat.
2. I removed the shifter trim and console to drill a hole and the bottom of the center console so the power and other cables could be run into it.
3. To install the head unit above the sun roof controls, I first removed the shade holder to access the front of the head liner next to the windshield. The holder just pops out and you have to remove a screw in the center of it. I then ran a wire from the top console along the headliner next to the windshield (tucked it under) and down the front pillar and under the steering wheel trim and down the center console and into the wire meet up point.
3. Antenna install - used a diamond removable hatch mount. I wanted to mount it low enough on the rear hatch so my small stub antenna would not hit anything too low. I then put a small hole into the boot that runs wires between the hatch and the cruiser roof. I then snaked the antenna wire through the boot and into the roof liner. The antenna wire was run on the edge of the roof liner all the way to the passenger pillar where it runs down under the seat and into the center console to meet up with all of the other wires.
4. External speaker was mounted up and under the driver side dash above the gas pedal (out of the way). It's a fairly large speaker, so I don't have any issues hearing the sound.
5. I hooked up a SWR meter to verify everything was working. Granted, by 1/4 stub antenna does not have much adjustments, but I was able to adjust my full wave antenna down to a 1.2 - 1.5 on all 2m and 440 frequencies. The Icom ID-880 has custom display colors, so I was sure to switch the LCD Display to green so it matches almost exactly the same color as the rest of the Land Cruiser's instruments.
I went for a drive today and was really surprised how well the 1/4 wave antenna works. I'll always keep my full wave antenna in the back for the out of town longer excursions. I really don't notice much difference locally with the 1/4 antenna. I can get into all of the major repeaters on my 12 mile commute route, so all is good.
Next project: Mounting my HF rig - Kenwood TS-480. This will be a much more involved project since I will be using a screw-driver HF antenna (probably a Tarheal...)
Thanks for sharing. Just need a little zoom on the pics. ;)
Opps.. I made them larger. Sorry about that. Picasa has a mind of its own.
That looks clean! I have a couple of projects in mind that require punching through the firewall. Were you concerned that you would end up tearing into any of the wire bundles when you punched through with the screwdriver? I have stared that boot down 3 or 4 times now only to chicken out out for fear of damaging the factory wiring.
Nice setup, we've got the same garage door opener.. :) I have one of those SBB-1 antennas too, and have run it low like you have it, it works great on trail runs but I notice a difference trying to hit the repeaters, or anyone further away. It's better if it's up higher, or at the edge of the hood.. but you can't beat the stealth mode for branches, for highways you can always swap a 5/8 wave on, which I find slides under the back seat quite nicely. ;)
pfran, got for it man.. they stay pretty well bundled together even on the inside of the firewall, as long as you're below the main mass you should be pretty safe. Just make sure the weather's nice tomorrow in case you have to ride your bike. :eek:
The good thing about using a screw driver is that I doubt it would really destroy the bundles of wires since it is not that sharp. I did it alone, but it would have been much easier if another person was on the other side to help guide the screw driver and wire through. Just take it slowly and you will be fine.
I'm impressed. Very clean and very nice! I have never made the switch to Ham. But, when I do I may have some questions for you!
Ham is the way to go. The test is easy and you will actually meet a bunch of cool people on Ham Radio. Plus, you can talk all around the world with D-Star and IRLP (Voice over IP on UHF/VHF radio )
Let me know when you have some time, I'll help you find a testing center and get you licensed!
Sandiegocruiser and Mnxdrks,
I'm also looking in getting a ham, let me know when you decide to take the exam and which unit you get. Might need some help setting up.:D:beer:
Thanks,
Jon
Thanks,
Jon
Cool, best way to get started is head down to Ham Radio Outlet off the 163/Clairemont Mesa exit and pickup a Technican Study book. They also have testing info down there as well.
SDC did you do any additional grounding to the antenna/mount? I've got a K400CNMO hatch mount I'm about to install and was wondering if I should consider addl ground.
Does your mount pinch the rear window rubber surround? Part of the K400 sits on the rubber.
Great info- thanks. Sent you a pm- want to install a rear spoiler like the one on your hatch and would like to know source of yours (no flaming requires here- wife's truck!:)
Please use a wooden cooking spoon. I used a screw driver 3 years ago and hit a electrical connection going through the firewall. It melted the rubber boot to the screw driver, deformed the firewall around the boot, and put a good sized electrical burn in the screw driver metal. I'm not sure what I hit, the truck was fine, but it was quite a scare. Just a heads up to everyone putting metal objects through a firewall.
Edit: fabulous install. Well done :clap:
Good idea. I find it's more about the angle that you poke the object through the rubber groumet. Make sure the angle you take puts the object far away from the center of the wire bundle. Glad to hear the truck was fine!
