ok folks I have completed painting my rims on the 100 and thought i would post how i went about doing it.
1. either buy a second set of rims or remove your tires from current rims, i suggest buying a used set because in order to do it right it will take three days.
2. buy spray on stripper (the kind that works in 15 min). I bought mine at HD, you only need the small can. Spray every inch of the rim with the stripper and let it sit for 20 minutes and then respray again. Let sit for an hour
3. Take either a pressure washer or a hose with a sprayer on it and hose the hell out of the rims and this will take 99% of the clear coat off along with any other paint...plus it washes the stripper off. You want to do this in a safe place so you dont kill your grass....i suggest you hose them off in your neighbors yard.
4. after washing i set them out in the sun to dry.
5. buy 100 grit and 220 grit sanding blocks, they look like dish sponges, and sand the entire rim and any remaining paint off. It doesnt really take much work. It took me 15 minutes a rim.
6. buy a good grade automotive primer, rattle can, and also buy one of those trigger sprayer things that clip on the rattle can. I feel like i have more control using.
7. prime the rims and let dry and then reprime. I let them sit a full day and then sanded and reprimed them a third time. Let them sit another full day
8. This is where you may decide to go a different route. I bought black Epoxy paint, the kind you use on appliances. It goes on thick, dries hard and has a good gloss.... somewhat like powder coating.
9. spray in sweeping motions b/c it over spray wicked bad if you're not careful. I let them dry in the sun....
10. Mount them...!!!
Pics below.
1. Rim after it was stripped
2. Rim after 1st prime
3. Rim after 3rd prime
4. Epoxy i used
5. Painted rim
6. Painted rim side view.
Pics below.
4. Epoxy i used
5. Painted rim
