I just bought a 98 LC in immaculate shape.
It has 80,000 miles on it, but looks like it should only have 20,000. Luckily the brakes were done right before I bought it. I am trying to anticipate other things that will need to be repaired. The timing belt replacement seems to be something that needs to be done around 90,000 miles. What are the signs that this needs to be done, or are there any signs before you have problems?
Also,
I am not sure when the fuel filter was last changed. Is it easily accessible? How about the fuel pump? Is it prone to needing replacement and if so, is it easily accessible? I had a Tahoe prior to this and the fuel pump was in the gas tank, which cost $600 to replace.
Any help or tips would be greatly appreciated. I look forward to putting another 100,000 on this vehicle.
Also,
You would think after 30 years of production that the 350 would be a great engine. ??? Suppose that’s why they use a different engine now? I’m into making something better/stronger & with the Tahoe I was just trying to keep it going. Besides it was horrible off road. Totally unreliable in my opinion & nobody wants them after 100K!
