Hi everyone,
I have a Stihl MS170 that does not deliver enough oil to the bar. It worked fine when new, but then didn't get enough oil to the bar. I have had it repaired at a Stihl dealer, who replaced the oil pump Pt. # 1123 640 3200, but it still leaves about three quarters of the bar oil in the tank for every tank of gas. I took it back, but they said that it was what Stihl had done for the environment. I didn't really believe that one!! I have taken it apart as far as I could (even committing the cardinal sin of using a rap wrench to remove the clutch. Fortunately after replacing it the saw still works.) and found that the worm gear was in good shape, and the driver spring did engage with the drum, and that the pump turned easily. I don't know what to do now. I have searched this forum, but could not find an answer. Perhaps someone would point me in the right direction.
This is a wonderful mine of information, and my thanks to you all.
Tony.
Tony.
