After a bunch of research and coming up with conflicting accounts of when a snatch block will "double" the pulling power I decided to do some testing in the garage.
Using 2 small blocks, a 30# chunk of lead and a fish scale I was able to confirm that when a single snatch block is attached to a fixed object it only changes the direction of the pull. The amount of force to lift the weight by itself was the same as when I put a block on the "fixed" point (a chain on my rafter).
When I attached the block to the lead and made the chain on the rafter the dead end it then lessened the amount of force required to lift the weight to about half or 16#.
The final test was with 2 blocks and changing the dead end from the lead weight to the the chain. with the dead end on the chain the applied force dropped to around 10# or in effect tripled the pull power and with the dead end on the weight it took around 16# again or doubled.
In conclusion: with 1 snatch block and attaching it to a tree you DO NOT double the pull power but only change the direction of the pull. If you are attached to another tree or object. Does double if attached back to the rig in effect making it the moving block.
If you are pulling out a buddy with 1 snatch block attached to his rig and you doing the winching you will have doubled the pull power.
And now having gone through this and being proven wrong I found the easiest testing method to be a comealong with the hook on the end of the of the wire rope that can be attached or removed from the main body and one pulley for doubling. Attachment points can make a difference.
