Cruisin Off Road M101 CDN Trailer Build
Cruisin'
Out in the shop, building something cool!
Grand Forks, BC
I recently picked up a CDN M101, which I'm going to be setting up for camping use over the winter. I'll start the thread now, and gradually update as the trailer takes shape. My basic plan calls for a lid with a RTT, a removable awning off the back, a tailgate, and a pull-out kitchen. I also use the trailer as a utility trailer, so I plan on keeping the mods easy to remove when I need to haul stuff instead.
First bit of progress was cutting in the tailgate. I used a set of 80 series tailgate hinges, mounted upside down. This allows the gate to sit below the level of the floor of the trailer when it is open (this will become important later...). I reinforced the panel with some 1x1 square tube, and left a 1" lip all the way around. I'll be using this as a sealing surface for the weather seal. I'm sourcing some door seal to mount just inside the box of the trailer so when the gate is closed it will be completely sealed from water and dust. Also I left the top rail of the trailer intact, since I don't need it out, and it will keep the structure solid and square. This will also keep sealing the lid easier. Haven't quite decided what type of latch I'm going to use on the tailgate. I will make it lockable, though I don't need to worry about rattles since the rubber seal will keep it snug.
And now, for the pics: First - tailgate down showing the reinforcement inside
Second - I wanted to keep the back of the trailer looking original, so you can hardly tell its been chopped.
Third - I'm going to paint it all Khaki when I'm done. I want to keep a military look to it, but the Khaki will match my truck nicely. I picked up some camo spray bombs to touch it up as I go though, so here's a sample of the colour.
-Jason
Did you make the tailgate removeable? When I do get to my trailer build, I will be making a similar tailgate but I was thinking that a removeable tailgate would be a nice touch.
I used the 80 series tail gate hinges, and bolted them on. I think having it removable might be a good idea at times too.
Very nice start. I really like what you're doing with the tailgate, too.:popcorn:
definitely going to follow this. jasons good at sticking metal together. whatever brackets or mounting solutions you've got planned for fuel/water cell & propane tanks make sure you make extra sets! :D
where'd ya find such a minty speciman? got plans to run pwr to it? let the fun begin...
Found it in Abbotsford. Guy had a couple of them. I picked the one in the best shape.
I'm thinking of putting a bracket for a BBQ sized propane tank on the front somewhere, and I'm in the process of making a removable jerry can rack to go on the ladder of my truck for carrying water. Idea there being to keep the trailer weight down. Of course I may decide I need more racks later for more water/fuel. That might come when I do bigger fenders with platforms front and rear (a la Greg_B's build https://forum.ih8mud.com/trailer-tech/317577-impressed-m101-stock-trim.html), but that will probably be next year.
Was at Stevenson Marine the other day looking at their stainless propane stoves and noticed these: Sure Marine Service, Inc. * Since 1972 * Marine Heating, Air Conditioning, and Galley Equipment Weight savings for the tow rig. Haven't thoiught through all the pros and cons of composite versus steel yet, but interesting none the less. Composite LPG Cylinder Test Burns: No BLEVE | Firehouse.com
Looking forward to details as they get figured, and mine is patiently waiting.
gb
gb
The composite is cool... Not sure if the extra cost is worth a 6 lb weight saving. Doesn't look like it would fit in a standard tank mount either.
But the cool factor can't be ignored!
-Jason
Tailgate seal
I've made some progress in the last while. The tailgate is all sealed up now. It should float based on how well sealed the back end is now!
I cut into the rear of the floor so I could recess the seal below floor level so it won't get thrashed by dragging gear across it. The hinges allow the tailgate to drop below floor level so the kitchen can slide out. I'll probably put some chains on it for when I want the tailgate open as a shelf, but most of the time it will swing down vertically so as not to be in the way while moving around at the back of the trailer. I need to change how the latches are oriented since they don't quite cinch the gate closed against the seal at the top, but that's not a big deal. I think I succeeded at keeping a very stock look at the back of the trailer, which is what I was going for.
Kitchen
After seeing the Drifta kitchens from Australia, my brother and I started thinking that would go real nice in the M101. Being a very talented wood worker and cabinet maker, he took on the job. I'm very pleased with the results. The kitchen has a drawer for a plastic bin sink, and another for cutlery. It has several cabinets for storing food, dishes, pots and pans, and other cooking related camping gear. The flip-up area will house the stove, and the extra counter space at the very end will be welcome too. On the back side is a fold-down shelf that sits at just the right height to eat at sitting in a lawn chair. This will be really nice at remote areas with no picnic tables. The whole arrangement weighs about 70lbs, and slides in and out on plastic slides on the bottom of the trailer. When the tailgate is closed the kitchen is held in place by tabs on the front wall and tailgate so it can't move around on bumpy trails. I just have to work out some legs to support the end when its pulled out and its good to go. :D
That thing looks great. I really like the slide-out kitchen - it looks like it belongs there.
I may have to steal some of your ideas :doh:
Looking great Jason! That is the way the iltis trailer should have been built----- with a tailgate.
Slick!
:beer:
