Well, it's not where it used to sit next to the armature growler. I was going to post a pic of it. No idea where it might be.
I've always had pure sine UPS's for my computers, network gear, monitors,WiFi, Verizon ONT and security system.Back with an update of sorts: I'm even dumber than I thought when it comes to inverters...
In the OP I had looked into what garbage waveform comes out of cheap inverters.
What I had not thought about but just dawned on me is that there are inverters in other ubiquitous devices: UPSes!
Obviously, right? Well I didn't think about it. But yesterday I fixed up an older UPS (tweaked it to accept a big LFP battery) and then realized that of course if the mains go off, you go on battery but then are completely at the mercy of the waveform coming out of the UPS. Looked into it and sure enough the waveform out of that thing is terrible, with a THD of about 40%. Highly modified sine wave. I would say worse than the one in the OP pic. And yet it's designed to power computers and electronics... Yikes!
So, yea, the same warnings should apply to UPS devices as well. Now, thankfully, the new ones may be better sine waves, but something to watch out for when shopping, I think. I'm seriously considering scrapping my older UPSes now given all that.
I love this idea. If you do this then there's no "switchover". I have a Goal Zero 1500X that I'll retire in favor of something newer and I'll have my computer and other sensitive gear plugged into that. That will mean continuous A/C power with the prospect of supplying power for a much longer period of time.Build your own UPS using a LiFePO battery with a LiFePO-specific charger and a Xantrex PSW inverter?
Costs associated with inefficiencies or life expectancy of batteries are to me of no consequence when it comes to expensive electronics, IMHO. The assumption is that a large 1500Ah battery would provide many hours of backup. But what if it isn't enough? The assumption is that I'd be around to shut things down if necessary. But what if I can't be around? So, the lack of integrated shutdown software is a real issue. It's something I'll have to think about. It actually sounds like a product idea. Good catch.^ I've done that and even had the battery being recharged with a solar panel, but there are a couple of issues with that approach -that may or may not be something you care about, of course- : First you are constantly losing energy because of the inefficiencies in the charger, inverter and battery and that will cost you; and Second -depending on the load and charging ability- the constant charging and discharging of the battery if any will reduce its life expectancy. Plus possibly that the waveform will not be as good as mains AC. Which is why real UPSes do AC passthrough and battery bypass, even some of the new LFP power stations. And you'll also have to be there to shut down the computer manually when the battery is discharged if the battery/power station does not support shutdown software.
But, yes, it works and is fun to see operate (I used the Victron software) and -if set up that way- to have your computer operate partially or even entirely on solar power.
