comes with both complete axles,chassis is a roller motor runs good miles around 30k bought from a friend, elect choke issue when cold nothing else
changed in a 83 trany/t case wont fit between center tube work it is set up for dual cases( cut and move or add dual's) both axles have o mile front is full rebuild 30 longs,complete v-6 brake with vented rotors 1,5 spacers 5.29's with a locker,rear is ifs with 5.29's spool (need fld added)both housing are studded as well as the front hub stud kit and stub caps no front hubs front spring are a mix of rears and 5" soft ride skyjackers w/ boomerang shackles, rear 4 link is still set up for 14" air shocks tire are 36x14.5x15 mickey baja's on 15x10( dont know back space)
gas/brake/clutch/e brake assemblies are there and work need to bleed clutch,currently starter,clutch cyl are not hooked up as I just put in trans,have radiator,motor has all assecories hooked up needs the 4 bolts to ac comp obo parts are in a box
air tank is still mounted it back has 2 ground cables but only a 10 gauge pos cable for starter
wired in all factory lights and have harness(89v-6 at 4rnr) to run headlights/offroad lights temp place carb fuel tank in back to test run motor and check wiring
needs rear air shocks,1 ton chevy master cyl, few brake lines,mount ps resivoir, bolt steering column to plate,high steer kit,seats
copy from an email I sent about details
