Got an 89 pickup with the 22re. It's always had a random little stumble here and there ever since I got the thing, but it never really bothered me because it was maybe once or twice a week that it would happen. Long story short, all of a sudden it just got really bad. Sometimes, well I guess most of the time at this point, it's so bad that I can't even get the thing up speed without it stumbling and bucking like crazy. It's very violent, and if i hold the gas down while it's doing this for too long, it'll either backfire (if I put the clutch in and free rev it, it sounds like it's hitting rev limiter at about 3500ish rpms and pops, sounds quite a bit like anti lag) I have better luck getting it any higher than about 3500rpms if I bring it up very slowly while free revving, and there's pretty much no way to get passed 3500 while trying to actually drive the thing. Either that will happen, or it'll just die altogether. I'll have to pull over and let it crank over for at least 10 or 15 seconds before it hesitates for a bit and finally starts again. I've literally never smelled any raw fuel, and I'm thinking if it was enough to flood it out I'd probably have smelled it at least once by now. I'm completely stumped, I've already replaced
Plugs
Wires
Cap
Rotor
Coil
Cleaned the **** out of the TB
Fuel filter
Seafoam in the gas tank and crankcase
The motor does have a good ground to the frame
I read somewhere that you can disconnect the vacuum line from the egr valve and plug both sides to bypass the system, not sure if there's any credibility behind that, but I tried it anyways
I'm trying to find somewhere to scan it for any codes, but apparently my truck is archaic at this point because nobody has an obd1 scanner...
I'm taking it to a shop this saturday to have a few little other things looked at, I'm gonna probably have this fixed too if I can't figure it out by then, anyone have any other suggestions?
Plugs
Wires
Cap
Rotor
Coil
Fuel filter
