1911 said:I agree in most instances. Why give up one of the major benefits of ham (10-20X the power) over other services? If all you're ever going to do is ride right behind someone else on the trail, and you live/drive near some repeaters that are way up high, then a 5-Watt HT may do you just fine - but the first time you are separated from your trail group, or have more than one trail group, or find yourself out-of-range of a repeater, you'll wish you had a mobile instead. If you don't want to drill holes for a permanent antenna, then use a mag mount.
You know this is all about antenna. A 50 watt versus a 5 watt transceiver, all other variables the same, is 7 DBm. Saying its 10x more powerful may mislead the new guys. I have and use both types of units on the trails and my point which remains is an HT is very useful outside of the rig and can be very effective with an external antenna for situations needing additional distance (gain). I have yet to need to turn up the power on my ft350ar more than 5 watts.
I think your comment should be "the first time you are separated from your group you'll wish you had an high gain external antenna."
I'm not trying to say one thing is better than another, I leave that up to the more opinionated members, I'm saying consider the options.
Sent from my iPad 2 using IH8MUD
