Taking preorders now at Yotabeast.com! Shipping ETA is now less than two weeks. These are currently in production.
From the manufacturer:
Toyota Tundra Odyssey Dual Battery Mount Kit
Need to install a dual battery system in your Tundra to power all your accessories? The XFAKTR dual battery mount kit allows for the installation of dual, side-by-side Odyssey PC 1500 series batteries in the stock location under the hood of your 2007-2018 Tundra! This results in a very clean and simple installation of your dual battery system with very short wire runs. Some of the kit features include:
• 100% BOLT-ON!
• Mounts any two Odyssey PC 1500 batteries (with top posts) in the stock battery location
• Professionally engineered, CAD drawn, and CNC-cut and formed
• Overkill 3/16” 304 stainless steel for extra rigidity and corrosion resistance
• Top plate will come DA sanded to a beautiful finish which can be left bare (how we like it) or is ready for your favorite coating
• Kit includes top plate, base, hook bracket, and all necessary hardware for installation
• Batteries not included
• Recommended battery: Odyssey 34R-PC1500T
• PROUDLY MADE IN USA
Accessory Tray (OPTIONAL)
• 100% BOLT-ON!
• Works in conjunction with the XFAKTR Dual Battery Mount Kit
• Swing away design allows for full access to the factory fuse box below
• Huge 13.7″ x 5″ and 13.7″ x 8.25″ mounting surfaces
• 2-1/4” clearance above the factory fuse box increases mounting surface area by allowing underside mounting of components
• Made from 1/8” 304 stainless steel for rigidity and corrosion resistance
• Includes all necessary hardware for installation
• XFAKTR Dual Battery Mount Kit required for installation
• Accessories not included
• 100% BOLT-ON!
• 100% BOLT-ON!
