an electric PS pump from I think a benz?
I searched found lots of discussion with little parts break down or newbie descriptions![]()
Title basically states it. I searched found lots of discussion with little parts break down or newbie descriptions
Early 2000s A class Benz had electric fly by wire steering.
Steering in the one I drove regularly was mostly ok had absolutely zero feedback from the road.
In an emergency lane chance scenario, it was laggy and scary.
Is return to center important to you?It also looks like they were going for overly complex... check valves and electric driven.
Bringing this up from the grave as I get closer to needing to figure it out.
Single-ended ram or double-ended ram? I've seen both brought up.
2x8, 2.5x8, or 3x8? Again, I've seen all mentioned.
For a control valve, I found PSC has this:
The price is a little more than I was expecting. Is there a better choice?![]()
FHDV-STD - Standard Directional Control Valve for Rear Steer
This Manual Directional Control Valve offers more progressive steering control than previously offered units and features balanced spools for smoother operation. Rated at 3600 PSI of constant pressure with a MAX flow rate of 10 GPM. This unit also features an adjustable relief valve. It can be...www.pscmotorsports.com
