SOLD WV-MD-VA: 1988 FJ62 with LS SWAP
Year
1988
  1. 60 Series
Mileage
274000
Color
rgb(0, 0, 255)
Outside Link
https://www.facebook.com/marketplace/item/668252758169753/
1988 Toyota FJ62 Land Cruiser
LS 5.3L Vortec (LM4 aluminum block) engine swap
4L60E transmission
274,000 miles - I do not know the miles on the engine, however previous owner said she had the vehicle 6 years and put 50k miles on it.
OME (Old Man Emu) 2-1/2” lift
Freshly painted (matching original two tone paint)
New FJ40 OEM wheels and hub caps
New BF Goodrich TA K02 tires (33 x 10.5 x 15)
New front & rear Toyota OEM bumpers with OEM end caps
Knuckles rebuilt
New windshield
New OEM rear license tag light assembly
New Champion aluminum radiator and electric fan
New intake manifold gasket
New thermostat
New water pump
New front brakes
New oil pan and gasket
Alignment
New oil pressure gauge
New carpet
2 layers of 80mil Kilmat under carpet
Air conditioning serviced
Crack free dash pad
Uncracked windshield washer bottle
Front seats reupholstered and rear seat lower vinyl reupholstered.
LED lights installed in dash
Upgraded 4 Runner front wiper arms
Upgraded FJ80 rear wiper arm
New OEM rear view mirror
Rear hatch glass removed and rust repaired.
New Blaupunkt rear speakers
original owners manual
FJ62 for sale - Google Drive - https://drive.google.com/drive/folders/1GBPVRiZtBEO5nJVQQHn3lAGc-iMsdwiO?usp=sharing
$45k
The price is 45k for posterity
Beautiful truck! I noticed the tachometer wasn't too happy with what was going on. I assume not calibrated/won't work with a V8, so its going bananas? I wonder if there is a way to convert the signal? I know I've done it on some tac's that were expecting 4 cylinders but it was a six.
Any idea what year/identification the motor/trans are for ease of ordering parts/servicing?
Thank you.
Thank you.
Thank you. I had a signal converter installed to have the LS talk to the Toyota tach - when driving normally it works fine however as you can see when I stepped on it, the tach was confused. The signal converter is programmable so it may need tweaked.
As for the engine and trans I believe it came out of a 2004 Trailblazer Ext
Do you happen to know who did the swap?
