Wanted WTB: Stainless oil hose or adaptor compatible with header for '68 F engine
Goforth
Austin tx
I put a header on my '68 after the factory exhaust manifold upgraded to two separate pieces. My existing oil fitting and line will touch the header. Photo of what I got where you see the straight adaptor which comes out of the block then the hose. (don't worry about the heat tape, that was my redneck insurance):
I'm looking for a solution, be it an adaptor with a 90 degree bend out of the block or a hose with a 90. Anyone have what I need or ideas?
Thank you!
Charles
Possibly the 90 degree brass fitting on the stock fuel pump will work if you can find an extra. We use to give these fittings with our Headers to route the line away from the Header.
Back again looking for help. I sourced the 90 degree fitting from stock fuel pump.. New issue is that my oil line doesn't fit that. So, should I source a different NPT fitting or new oil line that would work with the brass fitting (BTW, I can use the brass fitting for my fuel pump since I didn't have it.)
