justbecause
perpetually lost.
Land Speeder said:chicks in cruisers?! where?
I think I was drunk on mud one night and proposed to the girl who started that thread.... Gumby moved it to chat...
Land Speeder said:huh? I'm lost. So Will thinks she's your girlfriend?
There's alot of hawt girls in T-Town no doubt. I think ya'lls cheerleaders are hotter right now.
uabericm said:Thanks again Zac for the bushings and arms. I installed them yesterday at work and the truck drives a ton better. One night, Matt and I will push out the rest of the bushings in 'my' old arms and I'll keep them around for anyone wanting to do caster correction. That way, you can press your bushings in these used arms without taking your current arms off.
Here is a picture of my old bushings:
Man those things are rough! I hope your new ones stay together.
Matt since you have had bushings and drop brackets which would you recommend?
I talked to Will and he said even if I don't notice a problem now that I will if I go wheeling, pull a trailer, or go to 35s....
Does anyone run the caster correction arms?? I cant even remember who makes them I just saw a link once and I think they were as much or more than the OME lift kits.
Weird that he said that about the correction. From my experience low caster is most noticeable when you are riding unloaded on the road. Off road low caster keeps the steering lighter. If you add a trailer or a bunch of gear to the truck you decrease the height and increase caster, especially with the back loaded down. If you are worried about it I would get your alignment checked to see what the numbers actually are. Every truck is a little bit different. My truck seems like it was low on caster to start with, yours may have started high.
You definitely don't need plates or arms, they will be way too much for you.
bhmmapping said:I don't have drop brackets, I have plates. Plates give more correction than bushings. I felt like I needed more caster with the the part time transfer installed and the extra height I gained when I swapped the tranny.
