Thank you for the help. Which parts did you utilize off each vehicle ?
wrecker in Canada/USA
Can anyone tell me which parts specifically can be taken from an FJ40 and put into the BJ42 ?
The problem with the gasser amplifiers, at least the ones I've seen which is the FJ55 and FJ60, is that they need a coil signal to operate and last I checked there isn't a diesel that can provide that!! A decent A/C shop can create a control system though if that is all that is holding you up (that was done on the FJ55 and it works well).
There is more than one thread on here where posters have claimed that they were able to use the FJ62 amplifier in an FJ60 when converting to 1HZ. I believe the signal goes through the ECU on the 3FE not directly from the coil. Might be worth it for the OP to research this as an option.
