Wanted WTB: 13B-T timing gear case
Cloverdale, B.C.
Hello,
I'm looking for a 13B-T timing gear case (oil pump housing) to replace the one I broke when I dropped the drivetrain during the install.
Hoping someone has one they're willing to part with, or has a suggestion where one might be. I'm having a hell of a time locating one and tought I might try here.
Thank you for any help,
-Mike
i have a couple here off a 3B..let me know if you are interested ...how does $90 sound or let me know what its worth to you
would be a quick trip on the Greyhound to you..
Best Regards
Gord
Tried to use a 3B case already, the pump gears won't swap over without machining the cresent out of it. I might have to go this route.
The 13B-T uses improved pump gears like those in a 2H/12H-T or the later 3B II. I would like to use them if possible.
The 13B-T timing gear case is no longer available new either. I already have a replacement 13B-T cover, so I'd like to get the matching case.
-Mike
