On my '86 FJ60, the rear rails are "blistering" at the spot where a lot of these trucks tend to rot (between the aft end of the wheel arch and the rear shackle mounting point). You guys know, the way the two "C"-shaped frame rail parts (two sandwiched "C"s if you cut a cross-section out) start to separate from one another. Anyway, where I'm headed with this is why did this happen? Inferior metal? Lack of undercoating? This truck spent its life being garaged and aside from a little outer quarter rot, there is no rust at all on this rig. I just think it's weird how the frame isn't mint, or at least better than the body shell. Further, that part of the frame is OPEN, not a place where water or salt builds up. Any input from anyone? I guess with the extremes in temp we have here, and the humidity, salt roads...Anyone?
Thanks
Paws
Thanks
Paws
