ARCHIVE Wits' End giving a Delta product some pucking love
NLXTACY
Wits' End
Medford, OR
This is something that should ONLY be considered for your 80 Series Land Cruisder if you FIRST are installing Delta's 80 Series Rear Spring Retainer AND you are going to run either Firestone or Airlift rear bags OR if you are going to install King or ICON rear bump stops.
The Delta spring retainer is a great little kit for keeping the rear springs trapped under extreme articulation with a big lift. It keeps the spring in place. If your rear build begins and ends there then no worries. The issue we ran into was we had a customer running a rear Airlift airbag setup and the bottom of the bags want to make contact with the spring retainer hardware. We needed to protect it. After a discussion with Dave at Delta it turned out there was a similar issue with the small pads on some manufacturer's shock pads also potentially contacting the same hardware. This solves both instances.
Ordered on Friday. Delta retainers showed up Monday, Wit's End pucks showed up today.
Neat solution. I have King air bumps in rear as well as factory side frame bump stops on Slee drop brackets.
Looking forward to installing these next week. Thanks Joey and Dave!
Ugh. Ok I honestly didn’t picture there being crazy demand for these. But here I am, with a larger batch…
You can see the leftovers from the full bar.
