- Thread starter
- #61
For mounting options... Aren't there screw/bolts protruding from the underside of the dashcap for the dash speaker? Could you use those as a mounting point to hold things up a little?
Possible. I’ll be checking.
Don’t know how bad gas engines are but my 3b shakes and rattles the truck like an old war plane and can only imagine how much louder everything would be with a bare aluminum glove box... Maybe want to consider a liner to cut down on things rattling inside.
A place for a fuse panel or a fuse panel in the box?
When these are completed I'm predicting they will sell out. I want to get in line.
If you're aiming for a box that will fit either an FJ60 or an FJ62 the depth is limited by the FJ62's ECU.
View attachment 1605283 View attachment 1605285 View attachment 1605287 View attachment 1605288 View attachment 1605291
- Entire opening is 12.75”
- The left edge can move over about 3/16”
- The left side hole only exists for the OEM light
- Entire back lower section of back panel can move back .070”
- Entire right side can be flush. There is the main wire harness that will ride that corner so need to protect it
- The right side is optimal for wiring because it’s a 4” deep space to the right of the GloveBox
- The entire bottom off the GloveBox could easily drop a few inches but not sure how much that complicates bending. But it would give it a lot more space
- Next up is a replacement glove box door that allows the use of a real lock like a Medeco lock. This means adding in a reinforced slit at the top center of the box for the locking cam
Yeah with the FJ62, I am pretty sure the ECU sits right underneath the glovebox insert. I can take a pic tomorrow.
It does. I just had my insert out a few weeks ago plumbing vacuum lines for my 4WD/2WD valve. Doesn't leave any slack to make the bottom portion of the insert lower, but I think you can eliminate the bottom "step" and make the bottom completely flat in favor of an internal shelf.Yeah with the FJ62, I am pretty sure the ECU sits right underneath the glovebox insert. I can take a pic tomorrow.
