Wiring Maxima seats?
Enola, PA.
Does anyone know how to wire electric/heated seats from a 2006 Maxima. Nissan mechanic said just wire power and ground......no dice. The plug under the driver side has eighteen pins and I don't want to start experimenting and fry something. :confused:
Have the Nissan tech print you out a copy of the wiring diagram so you know what those 18 pins do. Happy wiring.
I don't have any personal experience with Maxima seats, but if there are 18 pins, you'll probably need to grab the connector and at least a short section of the wiring harness from a junkyard.
The Ford F-250 seats I'm going to install on my FJ55 had the same huge connector with a ton of wires. After digging around under the seat I found another connector that had 3 wires, snipped off the connector and found the ground and power. Hope yours is that easy.
