Wiring harness connections
Bay Area, CA
Hi all,
I was digging around the rear quarter panel where the rear climate control guts reside trying to figure out why the rear AC blower won't come on and I found a harness that had a couple of wires that weren't connected. After a closer look it looked as though the ends and the connectors in the harness were corroded and they broke loose. You can see some blue material in the pic that is the corrosion. What is the best method to get this connections re-established? There is corrosion inside the harness plug so that could be a problem and might require a new plug I suppose.
Thank you
