Hi All,just wanted to report on a easy fix on the driver side window.It was rattling and I knew it needed to be fixed.Prior to that the darn window came loose and went sliding down sticking up like a shark fin!
It turned out to be a loose then missing bolt on the bottom of the window track.I found the bolt in the inside bottom of the door!Got it tightened up and all put back together.works great.Sorry,I should have took some pics.
But it was a rush job,I thought about it but did not have any around.Thanks for the tip.It's easy now to get in there,If I have any more rattles creep up I will know what to do.
