Ok, I think that I understand now. (1) you are driving an hdj81 witha 1HDT engine in it (2) you don't know which tranny you have presently in the truck (3) you are really curious about a possible replcaement engine for the 1HDT because you are concerned about parts availability.
Assuming that I have this right, what country are you in? This GREATLY affects the question of both parts availibility and replacment engines. For example, among your "high end"
Toyota diesels the 14 and 15B are very popular in Southeast Asia and Australia and NZ but only a few can be found in the Americas.The 1HZ and 1HDT are more popular in Canada and South America but hard to come by in other parts of the world. It therefore follows that parts for each will be available where the engine was sold/ promoted. For example when I was looking at engines for my engine swap I really wanted a 15B but I couldn't find here in Central America anywhere. Had I found one, I would have had to order all parts in from Japan. That is how I ended up swapping in the 1HZ.
As to which engine will easily replace a 1HDT, they easy answer is the 1HZ. They are almost identically the same engine and if I recall have the same bolt pattern and use the same bellhousing so they should bolt up to your current tranny , whatever it is. BTW, Open the hood of your truck and look for the factory plate on the firewall. It will tell you what transmission you have in the truck. You may also be able to find a similar plate on the doorpost of the drivers side door, although I can't say for sure on that as mine never came with one.
The real trouble for you is that if you are anticipating parts availibility problems for your current 1HDT you are going to have the same parts sourcing problems for the easiest swap, the 1HZ, as they are almost the same engine and use alot of parts in common. Of course all of this begs the question of why are you worried about the 1HDT? There are very few known problems with the engine and if properly maintained it is said that they should go 500K kms before needing major work.
Assuming that the reason you are asking about the 14b is because it is popular in your region then we will have to know what tranny you have before we can say if that swap, using your current transmission, is possible.
