For Sale Wichita, KS: 2004 Land Cruiser
Year
2004
  1. 100 Series
Mileage
188000
Color
silver
Sale Pending
2004 UZJ100 Land Cruiser Thunder Cloud Metallic / Shadow Gray 188k
JTEHT05J642056994
In Wichita, KS 67147 airport code KICT.
Has rear seat entertainment. DVD in console.
I bought this in 2013 with 108k out of south Oklahoma.
I think the paint is in excellent shape. The interior is in good condition. It is not perfect. Will get interior photos this weekend.
2013 maintenance:
  • Timing belt, water pump, tensioners and idlers. Serpentine belt.
  • Fuel filter and fuel line from filter to engine.
  • Front Toyota pads and rotors
  • Front wheel bearings
2014-2020: Regular oil service at 5k intervals. Trans oil change somewhere in there. Fresh glass installed with sealant and done right. 285 Revos.
2018: Lift:
  • OME torsion bar
  • 2860
  • Nitrochargers
  • Slee differential drop installed
  • SPC UCAs
2019: Deer strike required new lights and grill, front bumper cover. Repair and respray to hood and fender for blend. No structural or mechanical damage resulted, it was a small deer. Elected to spray the moldings which were fading, and the driver's door for a chip. Truck looks really good, I am particular about these things.
2021: I had a spark plug strip out #8 two years ago at 180k and I took the opportunity to do a valve job on it. Replaced the heads with used Tundra heads with fresh valve job, a few guides were done and every valve got cut only a little. Fresh valve adjustment. Replaced most of the rubber throughout the engine bay, this was at considerable cost even from partsouq. I think I have receipts for $3000+ worth of engine bay parts.
Used:
  • Heads with fresh valve job
New:
  • Valve grind gasket kit
  • Over half of the shims
  • Head bolts
  • Timing belt. I had replaced the belt at 110k and it was fine but I went nuts on "while I'm in there."
  • Water pump and pulleys
  • Serpentine belt and tensioner
  • Cooling hoses including heater hoses.
  • Fuel injector clean and test
  • Injector grommets
  • Fuel lines
  • vacuum lines & PCV
  • 8 new coils, new plugs
  • Toyota starter (real deal, not reman, this was $500)
  • Fresh AC recharge with a little PAG oil added.
  • All parts Toyota.
2022:
  • New rear brakes (pads and rotors) last year.
  • Oil change.
Issues:
Coolant weep from throttle body, is steady and I have not had to add coolant.
Toyota reported leaking steering rack last time it was in for service. I have recently added oil.
CV Shafts are weeping grease from outers.
Exhaust is failing, have a leak from the muffler section. I was going to Borla this but I will let the new owner get what they want.
Speakers are not great.
Asking 18,000 17,000. Will consider offers. I am going to sell, I recently replaced it with a 200.
Link to images, including underneath shots. They appear red because the lift is red.
Not yet but headed that way.
