Whirring sound when turning left, goes away when turning right. ( what is it? )
AZ
Like the title says whirring sound when turning left goes away when turning right. I'm thinking either a bad wheel bearing or maybe u-joint but the turning thing would seem to rule out the drive shaft?
Ideas?
thank you in advance
I think you’re probably right that it’s likely a wheel bearing. I had the same issue and new wheel bearings fixed it. Of course check just to make sure before you spend the money and time fixing it.
Well thanks for the feedback, I'm thinking maybe to replace one or both hub bearings with the Blue Pit assembly which has the bearing installed in the hub already. Looks like a one:banana: job.
I did both sides at the same time from blue pit and it was definitely a one 🍌 job. Definitely worth the money to buy them already pressed together and ready to go
