Where the heck is tire pressure reset?
CT
With the colder weather coming in my LC had a tire pressure warning on. I checked all the tires and they look fine so I wanted to reset the monitor. However, I can't seem to fine the reset button. According to the manual it should be next to hood and gas latch but there's nothing. What am I doing wrong here? Any ideas? TIA guys.
all five sensors reset everytime the car is started...there is no manual reset.
what is it doing?
what is it doing?
+1 .... more info???
Actually there is a reset button.
Under the left side of the dash, to the LEFT of the knee airbags.
You need to hold it down for about 20-30 seconds I believe. Check the manual.
I know that's what the manual says. There's no button next to the knee air bag like in the manual.
It's way back there... Get underneath with a flashlight and you will see it. I don't think it wil solve your problem.
You probably have a blown sensor in one of your wheels, or your spare is low. It may take a trip to the stealer, oops I mean dealer, for this to get fixed.
The other option is to disconnect the negative battery line for 15 mins and then re-connect. Upon first startup the computer will do the same reset operation as the button. If the problem still persists you need to go into the dealer for sure.
Thanks Chimyz. I finally found it. It was waaay in the back and you were right it didn't work. I think it's the spare. I guess I do have to take that trip to my stealer.:grinpimp:
No problemo...glad I could help...sort of. Good luck with everything.
