Yes, it is the generic one, which means you have to replace the original wire with new one by one without screwing up. If you remove more than 1 wire at a time, you have more chances of screwing it up.
Ok that's good to know!
Do you think this solenoid wire could have anything to do with the carb solenoid?
Your kit will work just fine. Keep breaking it down one wire at a time and keep good notes.
Purple: start position of ignition to left blade on starter.
Red wire: do not use. To provide power to starter use a battery cable from the positive side of the battery and connect it to middle connector on starter.
As someone else mentioned you are going to have several circuits unused when you finish this job.
Keep us posted on your progress.
Bill D.
you should have a wire running to the solenoid that gets juice when you turn the key in the ignition - I don't know the EZ wire colors to assert whether it would be red
as Pin_Head said, you'll need to mate that harness with the OEM diagram and switches - one by one, and find proper ground for the devices
Any ideas on what I could be missing? Should I make sure every other wire of the enitre harness is connected before I try to get the engine to start? Or should I be able to start it with only the ignition circuit connected?
Smack the starter with a hammer and see if that wakes it up.
If not try jumping across from the battery cable terminal to the spade lug on the solenoid. This will eliminate all other possibilities than the starter.
The other thing is that you can get fooled about the adequacy of a circuit by testing it when it is open or disconnected. Even a bad wire will show 12V when disconnected and this may drop to near zero when connected.
Even if the starter won't turn over you will usually hear it kick on and sound like it's locked up. .
Why don't you take a picture of how the starter is currently wired so we can take a look.
Just to clarify, you do have a large cable running directly from the positive terminal on the battery and connected on the large (middle) post on your starter? The purple wire from the ignition to the small connector on your starter only excites the solenoid and tell it's it to turn over. Without the large cable from the batt. to the starter you will get nothing turning over.
No need to connect the other wires just make sure they aren't touching bare metal or each other. No need to create other electrical gremlins for yourself.
Keep up posted on your progress.
Nice pictures. More silly questions!
Is the red wire from your ignition switch hooked up to the battery or is that it coiled up on the valve cover?
What voltage do you have at the ignition switch?
Jumping the starter is essentially bypassing the ignition switch by using the power to the middle post and using a short wire you touch the spade where the purple wire is connected. This excites the solenoid and causes the starter to spin.
Keep going! Wish I was down the street so I could drink all your beer and help out.![]()
Wait, if you're are in ftw I probablycould come by! live in Dallas and work in Irving.
Will pm you my # and we can get you fixed up.
Bill D.
All the power to the chassis has to come from the battery and there is no obvious connection I can see.
The OEM power feed for the chassis goes from the battery + post through the fusible link via a large white wire that goes to the amp meter. There it joins power coming in from the alternator and then goes to the ignition switch where it splits into two main branches. One goes directly to the fuse block to provide unswitched power that is always hot. The other branch goes through the switch to provide power to fuse block for things like the tun signals that are only hot when the key is on. There are two main buss bars in the fuse block: One with constant power and one that has power only when the key is on.
HTH
