The constant power side of the fuse block, the ignition switch and the - side of the amp meter are all equivalent in terms of the circuit. Generally though, for high current, high power lines, it is best practice to keep the runs short and direct (fewer connections) so the - side of the amp meter would be best for an alternator on the passenger side.
Way back on the first page, I mentioned that the EZ harness isn't going to work well unless you get all new parts, like a GM steering column and you will need to either customize the harness or reuse the old wires or make new wires. This is one of those many situations. Forget about making the EZ harness work the way it is and your job will be easier. Think of it as a new fuse block.
