- Thread starter
- #41
I would recommend soldering the connections if you dont want gremlins down the road.
Thanks Curt. You mean for the ign switch?
everything, after you get it all working i would heat shrink and solder all connectors, that way they wont oxodize or brake apart as easily.
If you replace the wire, you have to use the same size or larger wire.
Jumping across the terminals is just a test. You don't want to have to get our of your truck every time you want to start it. It is also an easy way to turn the engine over when you are working on it. It might take 15 seconds to do it. Just use a screw driver.
reading though posts here, but havnt seen anywhere that the starter has engaged. does it work?
stock wiring diagram for 76.
http://www.globalsoftware-inc.com/coolerman/fj40/schematics/FJ40/1976FJ40/Haynes1976FJ40Page1.jpg
does that startercrank at all? you sure it works?
X2
I don't see any connection from the chassis and ignition switch to the battery.
No juicy, no worky.
The OEM power feed for the chassis goes from the battery + post through the fusible link via a large white wire that goes to the amp meter. There it joins power coming in from the alternator and then goes to the ignition switch where it splits into two main branches. One goes directly to the fuse block to provide unswitched power that is always hot. The other branch goes through the switch to provide power to fuse block for things like the tun signals that are only hot when the key is on. There are two main buss bars in the fuse block: One with constant power and one that has power only when the key is on.
HTH
It is pretty obvious where everything goes when you get your head under the dash and look for wires of the proper size and color code. One clue is that the power feed wires are larger than the rest.
The power comes from the battery via the white wire, which connects to the + lug of the amp meter.
All the power goes through the meter.
The power wire (white/blue) from the alternator joins the - lug of the amp meter.
Another wire runs from the - lug of the amp meter to the power post of the ignition switch.
Another wire connects to the power input of the ignition switch and supplies the constant power buss bar of the fuse block.
The Ign position of the ignition switch provides power to the coil and to the key on buss bar of the fuse block.
The start position of the ignition switch goes to the starter solenoid.
That is all you need to run the truck and provide power to the EZ fuse block.
HTH
The post labeled BAT (for battery) is the power input to the switch. IGN has the wires to the coil and to the switched side of the fuse block. The ST wire goes to the starter solenoid and ACC is for accessories part of the fuse block.
The alternator wire could connect at the fuse block, ignition switch or the amp meter. All these are connected together on the same line, so it doesn't really matter where they are physically connected because they are all electrically the same.
You need to replace the white wire from the battery to the amp meter and any other burned wire that you might need in the harness.
The EZ fuse block has to have a wire that connects to the battery somewhere for unswitched power. This should go to the ignition switch, then to the amp meter and then the battery. All power in and out of the battery goes through the amp meter or it won't work properly.
3. Same as the white wire. The White/blue stripe wire from the alternator connects to the - side of the amp meter too. There should be a wire there that connects to the ign switch, so look for it. It is a different color; maybe red with a black stripe.
